I have just purchased what was suppose to be a NOS D308R distributor cap with the PATENT PENDING script on the top but it does not fit my 67 327. The locating tab on the bottom of the cap is in the wrong place. It is opposite the hold down clip and should be between the clip and the window. When the cap is on the distributor the clips are not next to the area cast into the housing to hold the clips. Anyone ever see a cap like this or know what is is suppose to fit? Did any of the Vette fuel injection or transistor ignition systems use a special cap?
Thanks for your help
Kevin
Kevin
