'60 Questions - NCRS Discussion Boards
'60 Questions
    Infrequent User
    • September 30, 2001
    • 27
    '60 Questions
    #1) For a '60 VIN of late July, 1960, would a date of April 27 on the rear be appropriate?
    #2) I understand that some '60 270 hp models were equipped with a standard copper radiator as opposed to an aluminum radiator. Is there any way to find out if this indeed was the case given the VIN?
    #3) Is there a contact or search that could be performed in order to find out if a car has ever been entered in a NCRS Judging Event?
    Thanks in advance.
    Re: '60 Questions
    (1) NCRS Flight rules allow a 6-month window for date codes that are not specifically addressed in the appropriate Judging Guide and/or Judging Reference Manual.
    (2) No comment--no knowledge.
    (3) If you're an NCRS member, you can correspond with the National Judging Chairman, Roy Sinor, and ask about prior judging. Can't guarantee he'll respond (much of the files are manually warehoused)....
      Infrequent User
      • 27
      Re: '60 Questions
      Thank you Jack.
      • Loren L.
        • April 30, 1976
        • 4104
        Re: '60 Questions
        With regard to question 2, anything is possible - check the radiator support - if the hole for the drain is on the driver's side, it is my understanding that the car would have had a top tank radiator.
        • Dale Pearman
          Ditto *NM*
