After finally finding an acceptable "942" block and a set of "858" heads. I
am starting a L72 restoration rebuild for my 66 and have a few questions for
the list.
The heads are rectangle port, closed chamber and I believe they should be
106.9cc ? I have a set of TRW L2268 .030 forged pistons. Running that piston with a 106.9cc chamber I am told will produce 11.25:1 compression. I am curious if I can get away with this on today's premium pump gas?
The L72 solid lifter cam, does anyone have the spec's on this grind? Is
there another more efficient (with over 35 years of technology) or even more
aggressive cam that would still pass flight judging?
Is it true you can still get a correct oil pan and balancer from GM? If so
does anyone have the part numbers?
While looking at several of these blocks I have noticed allot of them have
been helicoiled for the head bolts. I have never really noticed this before
on other big block applications. Is it wise to go ahead and have this done
while machining the block?
Thanks in advance for your responses,
Brett
the list.
Brett
