First off, I have no history of how the heater worked because I have only been rebuilding my '63 since I have owned it.
I am testing the heater switch prior to installing it and noticed that of the three ON positions of the switch, the third position has both the 2nd position wire post and third position wire post connected to the center wire post. (Hope that is not too confusing.) What I was anticipating to happen was that each wire post would match each switch position one-for-one with respect to connecting to the center wire post (a SPTT switch). That only happened for the first and second positions. But, as I just stated, for the third position, the center wire post is connected to both the 2nd position wire post and third position wire post.
Drawing out the circuit and including the heater resistors (two resistors in series with a center tap) and the heater motor. It appears that what I stated above gives me both a connection from 12 volts (due to the 3rd position wire post) and directly to the motor and a connection via one of the resistors from 12 volts to the motor. This appears to just short out the resistor circuit. So, I thought that maybe the switch is bad (or dirty) OR maybe I am over looking something.
Can someone tell me if the switch should be a one-to-one with the center tap or what I described that my switch is doing is correct?
Gary
Gary
