Warning: Undefined array key 7403 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
AM-FM Radio -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Date coded stickers on the case. Some modest circuitry changes. And, time of manufacture changes to the front dial lamps, legends as described in the applicable NCRS Judging Guide books.
I don't have a 65 judging guide but I do have a 64. Apparently the 63 and 64 AM/FM radios are identical. The judging guide doesn't allude to anything peculiar about them. It states there is a small incscription of "Delco" at the bottom of the lens. Probably the only real visible difference is simply that 65 used different knobs. 65 knobs are unique, the center of 64 knobs is slightly concave while the centers of 65 knobs are flat.
My 64 station numbers are white on a black background. AM designator is the same (or faded green? hard to tell) while the FM is white letters on red background.
Hi! 64 Radio is distinctly different in two major ways. One, the AM and FM lettering are red and black and, two, on the AM band there will be two Conelrad warning station emblems near the top and bottom of the dial. CU!
