63 Muncie Extension Bushing Replacement - NCRS Discussion Boards
  • John Fleming
    Do you have to pull the transmission to replace the extension bushing and the rear oil seal on a 63 Muncie? The drive shaft was checked and found to be out of tolerence and the yoke is worn. I ordered both. I was told that the extension bushing and rear oil seal probably need to be replaced as well. Are there any tricks to replacing these two parts? Thanks for your help.
  • Joe Fisher
    Re: 63 Muncie Extension Bushing Replacement
    If when the drive shaft is out, you have room to access the seal, that can be replaced in the car. I own a 61, and it has been 30 years since I worked on a mid-year, so I don't know if there is enough of room.
    As far as the bushing, there are two ways. One is to remove the tail housing, not a job that should be done in the car. The other way is to use a special puller, used at the dealer, that grabs the back of the bushing while still installed in the car, then pulls it out. Then you use a bushing driver to install the new one.
