I'd like to hear any advice from owners of black cars in regards to waxing/polishing, such as products used and tips on getting a perfect, no swirl look. Henry
dressing a black car
Re: dressing a black car
Henry.......
Go to "zanobros.com" and look at the products for that application bc/cc. The products there seem to be the best using the product specified for the application intended. If you plan to use a buffer then use ONLY an orbital type to prevent burning the paint. These products can all be applied and removed by hand and a buffer will only speed up the application and removal. Use all the products recommended and you will be very pleased with the results. I have used and recommended these products to many others and the the results are always the same..........TERRIFIC. Good Luck, Bill- Top
