78 interior light wont shut off - NCRS Discussion Boards
  • joe tassoni
    Just recently , shut the vette off, looked out the window, interior was still
    lit up tried closing both doors etc,, had to remove all the bulbs,grin,,
    any ideas would be really great, ?bad courtesy light swithch, bad ground, ?timer on switch? thanks, joe t
  • Zachary K.
    • March 1, 1986
    • 162
    Re: 78 interior light wont shut off
    I've found this to be the delay timer. I'm not sure if they are still available though. Hopefully, Joe Lucia will see your post and give you more insight as to the availibility of this part.
    1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
    1969 L71 LeMans Blue, Bright Blue Convertible
    1970 L46 Monza Red, Light Saddle Convertible - Duntov
    1976 L82 Classic White, Firethorn
    2013 LS7 Black, Ebony, Convertible
    Moved on -
    2006 LS2 Black, Ebony, Convertible
    • John Liner
      Joe....
      Part #463498 Control Should still be avail. from GM at around $40.00.
      I had the same problem a couple years ago on my 79. To locate this timer mine was behind the glove box upper right corner of dash. I was told on some 78 and 79 they could be located also under the dash near the steering column area.
      My original one was orange in color the replacement was white.
      Hope this helps.
      John Liner
