If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I own a 1961 corvette. There are stress kinks beginning to show in the fiberglass above the center of the front fenders. I was told by another C1 owner that this can be corrected by replacing the front body mounts under the radiator. I would like to know:
1. what parts I will need
2. exactly how to go about replacing these body mounts
3. If replacing the mounts will correct the problem
Any help with this subject would be greatly appreciated.
Bob,
Before you begin, do a little more investigation. Often, the problem is that the bottom of the rad support is rusting out. Since the rad support also serves as the front body mount, this causes the whole front end to droop. As it does, the fenders start to bow out and crack. You should be able to check by jacking up the car and crawling underneath. Use a mirror to look at the support. If it shoes signs of major rust (cracks, flaking, very thin) it will have to be repaired/replaced
Rod
Install a new mount kit under the radiator support. The rubber gaskets decay over time and cause the front end to droop. You can add shims to achieve any height you want. (within reason). Give the fiberglass a month or two to readjust to each addition. When it looks correct stop.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
