I have just pulled out the heater control unit off the shifter console. While checking the operation of the vacuum switches I found out that they seem to work but are loosing a little vacuum.
It looks like they can be taken apart by pulling off the little clip that holds the lever in place. Before I have them apart and can not put them together again:
Is this the way they can be serviced?
There were two pieces of rubber where all the hoses run into and which attaches them to the 2 switches. I believe to remember reading in a post long time ago that these rubber pieces are not available and it is necessary to connect the hoses directly to the nozzles of the switches. Can anybody confirm this?
