Finally have some dyno runs on the 63, 327 340HP (advertized). The rebuild consisted of domed KB pistons +.040, a Melling "151" hyd. equivalent cam, stock 461x heads, stock "129" intake, and a Carter 3461S AFB carb.
Here is some stats.:
at 3800rpm, 342.8ft/lb torque (this was peak), 248HP, 12.0 a/f, 111.1 fuel mass.
at 5485rpm, 282.5ft/lb torque, 295HP (peak), 11.7 a/f, 146.9 fuel mass.
Now for the question. The torque appears close to the advertized torque of 344ft/lb @ 4000rpm, but what happened to the HP? Is the dyno program calculating different than what GM did?
One issue I had during initial start up was the AFB, floats, wrong primary and secondary jets and power piston pull down. These issues were corrected.
Any help to get engine to the advertized HP will be much appreciated.
Bob Mitchell #23202
Bob Mitchell #23202
