Where on the radiator can you find these codes and what if anthing must be removed. What are the correct ones for this year?VIN #194675S120082
65 radiator #'s/code
Re: 65 radiator #'s/code
Actually the dating format is year/month, not month/year. And being #20000, your car was built in June, so the latest date possible would be 65E for May and/or 65D for April. F would be the same month as the build date which isn't typical and G is after the build date. Part number is 3155316.- Top
