Fiberglass vs metal rear spring "63 - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    I saw John's post yesterday re: fiberglass spring. I will be replacing the spring on my 63 convertible, and wondered if the ride really improved with the fiberglass ? Pros & cons ? Good or bad experiences ?
  • Dennis F. King
    Re: Fiberglass vs metal rear spring "63
    Steve
    If your considering a fiberglass spring I assume your car is a driver. That said, the fiberglass spring does provide a better ride when coupled with a set of high quality gas shocks. The rebound and jounce rate is more even across the movement range. You might consider matching the front springs to the rear. Contact Vette Brakes and Suspension in FLA.for additional tech info on this aspect.Hope this helps!
