1967 Build Sheet - NCRS Discussion Boards
1967 Build Sheet
  • LARRY WICKLUND
    1967 Build Sheet
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 1967 Build Sheet
    I dont have the information right in front of me but there was an option for the windshield and one for the other glass.
    The number is a number that was assigned to the body when under construction. You should find that number in other places all over the car.
    • Dennis Rosenthal
      Larry, the Y codes (Y60 is this case)were only used on the AO Smith built cars. at the top of your tank sticker you should see DOW-SMITH printed, and your body number should start with an A. For some reason these Y codes denote options that required some sort of modification to the body only of the car. you should also have a Y code for your paint color. I have a list of these Y codes. Dennis
      • Jim Hansen
        Larry: I'm in the same boat, have tank sticker, zone and dealer number, but can't find the name of the original dealer. I e-mailed GM twice requesting information, but it doesn't seem to have any. You might try www.window-sticker.com (Triple A Enterprises) which prints original window stickers for a nominal fee. Triple A has a pretty good list of original dealers correlated to zone and dealer number. You might get lucky. Hope this helps, Jim Hansen
        • George C.
          • December 1, 1988
          • 583
          Hi Larry, 27 was the New York / Long Island Zone .
          • LARRY WICKLUND`
