I had been having the usual hot restart/rough run problem on my 62 and got a lot of advice regarding insulating the spider/fuel meter from the engine heat etc. I have also tried a number of flavors of name brand gasoline with no noticable change with any of them. It seems the last few times I have driven the car that the problem is growing worse. It is now to the point that the car will start to surge at idle after it has been driven long enough to get hot and then allowed to idle for a couple of minuets, such as at a traffic light. Before, it only occured after a hot restart and then once it cleared up I was good to go until the next restart. When the car is first started and warmed up, it runs perfectly until the first hot start. Very, very frustrating.
Is there a brand of gas anyone has used that seems to do better?
Any other suggestions? I was going to try using the earlier model gasket that covers the area underneath the plenum, but John DeG. advised me that it would not fit without significantly modifing the plumbing.
I have a very strong desire to keep this old fuelie a fuelie, but I gotta be able to drive it!
If you have no suggestions, sympathy might help.
