1973 Starter Ground Cable - NCRS Discussion Boards
  • Roger C.
    • March 1, 1998
    • 83
    Please advise the attaching point of the cable from the starter to ground for a 1973 350 auto coupe. The assembly manual does not illustrate it clearly. Thanks Roger Clark Lubbock TX
  • Chuck G.
    • May 31, 1982
    • 2029
    Re: 1973 Starter Ground Cable
    Think it goes as follows: From the starter...a stud goes through the starter brace, and is secured with a nut. One end of the cable goes there. The other end goes to the frame in the vicinity of the right motor mount. You should see a hole in the back of the frame piece where the motor mount attaches. Hope this helps. Chuck
