The book says there were two water pumps used on 63 L84 (and L76); 3859326 and 3782609; early 63s used the 609. Which pump should I use for #3901 built 27 Nov 62? Thanks much in advance for the help and best regards to all. steve
Early 63 L84 water pump
Re: Early 63 L84 water pump
Tom and Steve-----
Both the '609' and the '326' have the large boss on the top of the pump which is drilled and tapped for a 1/2" NPT fitting (3/4" on MUCH later '326' castings). However, I really think that Steve's car should have the '609'.In Appreciation of John Hinckley- Top
I have confirmed that #3914 definitely has the 609 water pump. I have owned this car for more than 20 years and have no reason to believe the pump is not the original.
Steve's car came down the line 13 cars ahead of mine so I think the 609 is a pretty safe bet!!- Top
