Trailing arm bushing - NCRS Discussion Boards
  • Mike Sasser
    I have bought new polyurethane bushings for my 65 trailing arm assembly but am having second thoughts about using the poly bushings. Should I use original type bushing?
    Re: Trailing arm bushing
    Mike-----
    Yes.
    • Boyan B.
      • August 31, 1999
      • 187
      Use the origonal type. Some of the aftermarket (energy) bushing sleeves are too small for the bolts. Also when you have to install the shims, the washers (which were originally crimped) fall out and its hard to align everything.
