66 Brake Master Cylinder Repair ? - NCRS Discussion Boards
  • ronnie robertson # 36786
    I am rebuilding my master cylinder, and the new kit has a thick rubber washer and a check valve, as well as other parts (no instructions). When I disassembled the master cylinder several months ago, I didn't make note of it having a inside rubber washer or a check valve in the cylinder. I have a 67 service manual, but the master cylinders changed 66 to 67! Other documentation I have for other Chevys show a rubber washer and a check valve as the first two parts in the cylinder.
    Can anyone tell me the parts and sequence which go in the cylinder for a Corvette.
