The back part of my Instrument panel has a round solernoid with nothing attached to it it 1960959 DR(in the middle)and 5MF could not find any loose wires for it. The other solernoid was under the dash on the left side screwed to the steering support bracket it had a wire coming out each side and it was not hooked up to any thing and no numbers were found on it. there was also a brown slip wire(like the black ground that attaches to the panel)coming out of the wiring harness on the right side of the wheel that was floating around that when I put power to it the radio came on. The radio works fine with out it? The reason I took this apart was the panel lights were not working now I checked them all with aux power(from the cigerette lighter) and all lights work individually and my dimmer switch did not work with rotation and over ride for the interior lights. Any help would be appreciated.
I have ordered the 65 manual from the NCRS (has not arrived)do I need A better book for the electerical diagrams. NCRS #37372
