I would like to share with everyone, the following email response from Holley Technical support regarding my '67 Holley 3810 carb woes. The problems included hard starting, and continuous fuel leakage onto the intake manifold from the secondary fuel bowl:
The problem is a combination of too high of a fuel level in the secondary bowl and possible warpage of the secondary metering plate causing a leak. This can be found by looking down the secondary throttle bores after shut down and noticing if fuel is on the secondary throttle plates. If the problem is found you may have to change the secondary metering plate. The part number is 134-22 and we recommend this company for purchase, Chicago Corvette the phone number is 708 458 2500.
I found their suggestions very useful. I can't wait to replace that metering plate to see if I can finally stop these problems. If you have a Holley carb question, you can contact Holley Tech support at: support@holley.com
Craig Jewett
'67 327/350 A/C coupe
Craig Jewett
