I have a moderate vibration noticed mostly under acceleration. The shake seems to move from side to side. In an attempt to eliminate it, I have done the following: new wheel bearings, new u-joints and balancing of the drive shaft, wheel balance, new ball joints. The car also has recently gotten a new fiberglass leaf spring and Monroe Sensa-Trac shocks. The car is a 327-300hp 4sp, NCRS Top Flight 2 times. I am thinking next to pull the 1/2 shafts and balance them with new u-joints, check the motor mounts and any other rubber isolators in the driveline.
Also, the car incurrs a second, less noticable vibration at higher speeds (50mph and above) that seems to be unrelated to the first. This is more of a shuttering or high frequency vibration I can feel in the floor under my feet.
Before I get into some major stuff like the flywheel or engine and transmission internals, does anybody have any thoughts on what I should do next?
