60 turn signal assembly - NCRS Discussion Boards
  • Matt F.
    • June 30, 2002
    • 79
    Can anyone direct me to a diagram of how a '60 turn signal is put together? Mine came disassembled when I bought my car, and I can't find any visuals on how to put it all back together and reconnect the wires.
    thanks-
    Matt
  • Ed Jennings
    Re: 60 turn signal assembly
    Matt, I have a picture on disk that I took a couple of days ago for someone else of the cancel cam installed. Is this what you need or are you looking for the switch itself? I can email you the pic. As to the wiring, there is a C shaped connector that the wires from the switch hook to. They just connect to the corresponding color wire.
    • Joe Maulsby
      I took 60 turn signal unit apart last night and believe I still remember how it goes back together. If you need to call me at home, I would be glad to walk you through it.
