1967 Clutch Noise - NCRS Discussion Boards
1967 Clutch Noise
  • Mark Jekot
    1967 Clutch Noise
    Driving to work on a beautiful Colorado February day, I notices a little noise coming out of my clutch pedal. It was kind of a rubbing, tap tap tap tap noise. It went faster when I sped up and slower when I went slower. It went away when I applied a little pressure to the clutch pedal.
    I diagnose this as either an adjustment needing to be done, or as a throwout bearing needing attention.
    How far off am I?
    Mark
    #33661
    Denver
    • 15610
    How much freeplay does it have?
    Should be about an inch at the pedal. Also check the linkage to be sure all the correct parts are there for a '67, especially all the springs, and you might check the bolts under the dash on the pedal linkage to be sure they are all tight.
    • Mark Jekot
      Re: How much freeplay does it have?
      About 1.5 to 2 inches. I'm assuming this is measured from fully out till resistance is felt..........
      How about a source to tell if all of the springs are the right ones for the 67..
      Mark
