Sitch on pocket insert....
So the stitch length is the same around the entire perimeter of the map pocket? Inotherwords, when they were sewing around the corners the stitch length stayed uniform. Kewl. I think that may be one way to tell originals from at least one variety of repros then. Whether it applies to 1970 needs to be confirmed also.
Next Q I have is, how does the stitch length on the map pocket insert itself compare with the stitch length on the dash portion? Are they the same? I believe what I have in my '70 is the original dash piece. I know that I have a replacement pocket insert. It's stitching is longer (by about 50% than the stitching on the dash piece). Here's a picture: THingk is, all the cars I've looked at (admittedly there haven't been THAT many) - the stitching on the map pocket insert was significantly longer than that on the dash pieces. QUestion is - was it that way from the factory or has it just been that I've only ever seen repro ones?
~Juliet
~Juliet
