I recently replaced a damaged steering arm on my 68 with a refurbished part, which I was told was a 68. It looks identical to the previous one but I didn't actually line them up side by side, well anyway the front end is all back together and the left tie rod end rubs against the tire?? I haven't set my camber yet and it looks to be quite positive (about 5%), but could the camber cause the tire to rub the tierod end? What should the approximate distance be between the tie rod and the tire (the right side has over an inch)? I have standard 7" wheels. If the steering arm is off a later model could that be my problem?
Thanks, Jim
Thanks, Jim
