Mid-year washer pump - NCRS Discussion Boards
  • Dave Stafford
    I'm replacing (trying to) the washer assembly on my 1967. The re-built one is here but I can not get the cam assembly to match up w/ the slot in the new mechanism. Tried to get the wipers to rotate somewhat to help in the alignment, but no luck. Any experts out there with advice?
    Dave Stafford
  • Bill Clupper
    Re: Mid-year washer pump
    It does together with a slight load on the pin, so the trick is to get the pin into the proper hole in the cam, and then push back against the spring pressure to line up the screws.
