fuel tank replacement or repair - NCRS Discussion Boards
  • Ray G.
    • June 30, 1986
    • 136
    Hi Folks, I've got a 74 ragtop that is very original. I am replacing the exhaust system so I thought before I weld the mufflers on I should drop the tank (and get the sticker!) and either replace the tank, (I'ts not leaking, but does have surface rust)or use one of those products that is supposed to seal the inside. I just dont want to waste my time. A while back I replaced the tank on my 69 BB, it went pretty smoothly. Whats your opinion?? Thanks Ray Greene
    Re: fuel tank replacement or repair
    Ray------
    My opinion is that, if it were me, I'd replace the tank. A fuel tank is a critical, SAFETY related item. If it was anything but perfect, I'd replace it. The exact reproduction replacement tanks available from Quanta make it an even easier choice, in my mind.
    • ERIC FAIRCLOUGH
      I BOUGHT A GAS TANK FROM QUANTA. IT WAS A PERFECT REPRODUCTION OF THE ORIGINAL. IT WAS REALLY IMPRESSIVE THAT IT WAS TOTALLY IDENTICAL. IT'S NOT WORTH HAVING THE OLD ONE WELDED. ERIC
