59 starter shims - NCRS Discussion Boards
59 starter shims
  • Larry Allen
    59 starter shims
    The starter makes a "rrriiipppp" sound just as the engine fires. It sounds as if the ring gear is not clearing the starter gear for a split second after the engine kicks in. Do I need more shim or less? What is the correct clearance and where do you measure? The ST-12 refers to the Passenger Car book and I don't have a copy.
