66, 427-400? - NCRS Discussion Boards
66, 427-400?
  • rick erickson
    66, 427-400?
    when did the magical change happen in 66 that made 400-390 and 450 -425 and were cars actually finished with 427 -400 on the air cleaner decals, i have heard mid november build dates is this correct thanks.
  • James C.
    • November 1, 2001
    • 137
    Re: 66, 427-400?
    I have a 427/400 67 Vette. The engine was built on November 15, 1966. The car was built on November 23rd.
    • David D.
      • 330
      Re: 66, 427-400?
      Rick, In Noland Adam's Vol II, he states a 66 coupe #5673 is a documented 427/400 car. The last documented car, when the book was printed. More may
      have "surfaced" since then. Dave
      • Allen Zubatkin
        Re: 66, 427-400?
        What time frame would that VIN represent? Late November? The reason I am asking is that I was under the impression that this transition took place much earlier, like early October.
        Any comments?
        • David D.
          • 330
          Re: 66, 427-400?
          Allan, I don't have the "Birthday Book", but it would have been built around the end of 2nd week in November, on Friday 12th. Maybe someone with the "Birthday Book" can pinpoint it a little closer. Hope this helps. Dave
          • Dave Stafford
            Re: 66, 427-400?
            Are we talking of the change to '67 Model 400hp motors, or 1966 Corvettes with 400hp Tri-Power induction systems? I was surprised to see the post about the documented '66 Coupe w/400hp rating. Never thought there was one. On the '67 model change to Tri Power, wern't they produced in early Sept of '66?
            Dave #33944
            • Bill Stephenson
              Re: 66, 427-400?
              Dave,
              ------In the same way early 427 solid lifter 66 engines were rated 450 instead of 425,390 hp engines were rated 400hp.The derating of both happened app.the same time,although there seems to be some confusion as to when that exactly happened.I had a 400 horse AC car with a window sticker many years ago so I know they existed!...........Bill S
              • David D.
                • 330
                Re: 66, 427-400?
                Bill, Attempting to research the early 1966 L72 Convertible I have now (built approximately November 11th, 1965), is how I noticed that Noland ran across the documented 400 hp car, in his survey at that time. Dave
