71 LS6 cam specs
  • Jeff Morgan (31791)
    • February 1, 1999
    • 124
    #1
    71 LS6 cam specs
    Does anybody have the duration specs @ .050 ?? The one book i have shows 306 at .015 I am trying to compare it with the current cams that are available. If you have the lift numbers that would also help. I believe it was around .500. Any recomendations????
  • Joe Lucia (12484)
    • 42936
    Re: 71 LS6 cam specs
    jeff-----
    Intake and exhaust VALVE lift are both 0.520" with 1.7:1 rockers
    Intake and exhaust duration @0.050" lift are both 242 degrees.
    • Tom Freeman
      Check this site for stock cam specs: http://www.geocities.com/MotorCity/D...00/cmspec.html
      Stock Cam Specs
