Ventilator window assembly - NCRS Discussion Boards
  • John M.
    • January 1, 1998
    • 813
    I have removed the ventilator window assembly for rechroming and do not see how the guide rail for the main window is attached to it. Is it blind riveted? There is a screw and tab at the top and another attachment at the bottom end of the vetilator triangle. How is this attached and how is it removed/re-attached?
    Thanks for all advice
  • Jerry Clark
    Re: Ventilator window assembly
    John:
    It is rievted under the window weather strip, (track runner) in two places , if memory serves me correctly. The rivets will need to be cut and replaced after rechroming.
    jer
