'60 Moulding Problem - NCRS Discussion Boards
  • Ted L.
    • May 31, 1999
    • 101
    Greetings,
    I received the side trim for my '60 today from CC and most of the pieces are OK but the right front fender trim is too straight at the front curve. The front 8 - 10 inches is not bent enough causing the tip to misalign by 3/8". I'd send it back but I'm pretty sure a replacement would be the same way. Has anyone had any experience trying to bend this stuff? Looks like it would be easy to kink. How much heat could be applied without discoloring the stainless?
    Ted #32350
  • Dale Pearman
    Re: '60 Moulding Problem
    Don't try to bend it. It won't bend without a crinkle. Position the entire piece rearward and remove some of its end near the door if necessary. Classic problem. Only other solution is creative fiberglass rework.
    This is a critical observation in Bow-Tie judging.
    Dale.
    • Dale Pearman
      P.S.
      It's "molding" as opposed to "moulding". That misspelling has perpetuated in the TRM & JG for years!
      Dale.
      • G B.
        • December 1, 1974
        • 1407
        They just copied GM
        I bought quite a few '58 - '61 front fender side moldings back when they were available from Chevy. Just about all of them fit like you described, even when the fender fiberglass was unmolested.
        • Ted L.
          • May 31, 1999
          • 101
          Moulding vs Molding
          Dale,
          You are right. The Judging Guide probably got the misspelling from the same place I did, Corvette Central's catalog.
          Ted
