If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Finally got around to bench testing my fuel nozzle spray pattern on the 61 as outlined on this post in the past and the service guide pg 6M-25. When using the drill to operate the gear pump, should I go clockwise or counterclockwise? Turning the cable slowely clockwise causes it to bind after around 10 turns, seems to turn counterclockwise easily. I'm afraid to go any further until I get the correct direction. No mineral spirit spray yet.
Ron
23246
Rotate your distributor in a manner that turns the rotor clockwise as viewed from the top (or crank the engine) and watch the rotation of the shaft drive for the pump
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
