1961 Radiator Question - NCRS Discussion Boards
  • M W.
    • July 31, 2001
    • 835
    I recently traded for a true 1961 radiator from a local friend in my area. My question centers around several numbers on the cast of the top neck and a series of numbers next to the center support knob. The neck contains the part number as well as D10 20. The second series of numbers are 3490. They run vertically where the saw cut would be on a 62 model. Does anyone have any idea what these represent? Any help would be appreciated. If this helps my Harrison tag has a 60L date on it.
  • Dale Pearman
    Re: 1961 Radiator Question
    The CAST inlet neck on your 1961 radiator (with the square platform on top) contains cast embossed job lot numbers and/or cast embossed identifiers.
    Dale.
