Leaf spring fix - NCRS Discussion Boards
Leaf spring fix
  • Larry Barickman
    Leaf spring fix
    In the process of replacing the side yoke on my 69, I dicovered a broken leaf. It is the smallest arched one with three flat ones above. The rest of the spring is very good and not flat and ride heighth is correct. All of the leaves look fine except the broken one. There is a place here that can make one leaf. Is that an option or?
  • Ed Jennings
    Re: Leaf spring fix
    If you are in or near a city of any size, there is likely a spring repair company(s) that will specialize in repairing truck springs. They can probably help you out. Check your Yellow Pages.
    • Gary S.
      • July 31, 1992
      • 1628
      Re: Leaf spring fix
      Larry, e-mail me off line and I will check out the spring I have in the garage. It came off of my 66 and I have no further use for it. If I have what you want, you can have for the cost of mailing.
      Gary
      schisler@city-net.com
