Hello All,
Well, this week's project is to replace the outer heater box which someone had grossly tried to repair. Upon inspection of the heater core I found that it has been leaking. I started to try to remove the inner box so I could get the core out, but I'm finding that it is not as easy as it looks. Will I need to remove the dash to get the inner heater box out so I can replace the core or do I need to be more patient and massage it out? I'll admit I'm a real novice to this procedure. I looked in the AIM guide and researched the NCRS archives and found no info. So once again, thanks in advance for any advice!
Gerald
Gerald
