67 Side Pipes - NCRS Discussion Boards
67 Side Pipes
  • Jim Dulle
    67 Side Pipes
    I have a 67 Coupe with side exhaust. Can someone tell me if these were factory istalled only, or did dealers retrofit side exhaust upon buyer request? I can see where the rear exhaust exit holes have been filled, but the side pipes appear to be original, and the previous owner tells me they are. Thanks for the help.
  • John S.
    • July 31, 1990
    • 292
    Re: 67 Side Pipes
    I'am sure dealer's installed them for customer's. I had a Corvette shop and install them for customer's. I would say some one added your's.
      Agree....
      Side exhaust at the factory exploded (impacted) a number of 'upstream' assy areas including body build. If was was equipped with this option, 'mods' had to be made to the body in a number of areas including the rear valence panel--an alternate assy without holes for through-frame pipes was used.
      The fact that your car's rear valence panel shows evidence of glass 'fill' suggests (STRONGLY) it was not a factory original 'piper' car and you should expect a full deduction for the exhaust system during concours judging. But, if you bought the car to drive/enjoy, relax--drive/enjoy!
      • John S.
        • July 31, 1990
        • 292
        Re: 67 Side Pipes PS
        It's been along time, but when I installed these cover's & pipe's I beleive I had to cut off the bottom of the frt. fender panel for the cover to extend around. Did the factory put on lower panels that were already cut for the side pipe cover or did they just wack it off like I did.
        • Brandon K.
          • April 1, 1997
          • 474
          John, according to the AIM, the factory "whacked" both front and rear tabs on the fenders for the side pipes. Maybe someone else can elaborate on this.
          Brandon
          • John S.
            • July 31, 1990
            • 292
            Re: 67 Side Pipes More info
            That's right the rears had to be cut off also. It's only been 25 year's or so since I've done one. Thanks
