High quality distributor weights? - NCRS Discussion Boards
  • G B.
    • December 1, 1974
    • 1407
    I've finally exhausted my personal supply of used distributor mechanical advance weights.
    Can anyone recommend a source for good aftermarket replacements? Apparently GM no longer sells any weights for pre-HEI distributors.
    I've tried the hot rod type generic weights and found them to be a very poor fit. They usually have enough meat to whittle down to one of the stock shapes, but I'd rather find a bulk source that will sell me weights I can use without modification.
  • Don Shirey
    Re: High quality distributor weights?
    Jerry,
    Contact Jim Dwyer at Hi Tech Innovations in
    Holiday, FL. at 727-942-4003. They make the dist.
    shafts and cross gears for the industry. Perhaps
    Jim could provide you with a contact name.
    Don
      Jerry-----
      I can't tell you where to find replacement distributor weights, but I can confirm that all of the GM weights are discontinued. GM no longer manufactures ANY parts for pre-75 point-type distributors. However, the still SELL rotors, caps, points, and some vacuum controls. These parts are, basically, aftermarket parts in Delco boxes.
