Accessory Bracket Order on 69 L46 - NCRS Discussion Boards
  • Ken Lux
    I was wondering if anyone knew in which order the accessory brackets are attached to the water pump bolts on a 69 L46. Specifically, one with no A/C or PS - just water pump, alt., and AIR. Also, I'm curious about the AIR drive belt - does it encircle the AIR pulley and water pump pulley or does it also encircle the crankshaft pulley?
    Wanna make sure I don't ruin the water pump shaft seals.
