I've been trying for months to get the right rear brake drum off my '60. I know for a fact that the brake shoes are adjusted all the way in and I've pushed the disconnected parking brake cable in to ensure it's not engaging. I've pryed, hammered from the front, hammered from the back, hammered on the hub, cussed, hammered screwdrivers in the holes on the face of the drum to try and get some separation, soaked the hub in silicone lubricant, soaked it in liquid wrench, heated it with a torch, and have had other people try their luck and nothing.., nada.., nyet.
The drum seems to be cocked on the hub just a little. I can get movement on all but one section of the drum, but that one section seems to be welded to the hub. A friend tried to pry it off with a large screwdriver and broke the tip off between the backing plate and the drum. I'm fairly sure the broken piece is now wedged between the drum and shoe because it drags.
I would think there would be a brake drum puller tool but no one I've asked has ever heard of one. I'm to a point where I don't care if I destroy the drum in the process, I just want it off.
Any suggestions?
Any suggestions?
