Transmission Numbers - NCRS Discussion Boards
  • E.Nejus
    Found these numbers on the transmission on my 66 coupe. I believe the case # 3925660, these other numbers were located on the case or on tags; 10w110361, 952659w8, and POM19A. Curious as to what year this tranny is, Thanks in advance Ed N.
    Re: Transmission Numbers
    Ed----
    Your transmission is a wide-ratio(2:52 low)Muncie 4-speed that was originally assembled on August 19, 1970. Also, I believe that it was originally installed in a GM passenger car produced at the Willow Run, MI assembly plant.
    • William C.
      • May 31, 1975
      • 6037
      FYI, all '66 trans used the case casting ending in "010", and did not carry a ratio identifyer as a part of the trans assy code (P----)
      Bill Clupper #618
