Ed, These are low choke carbs....Since my posting, I have found that Corvair carb fuel inlet fittings are identical, but use a smaller fuel line....Phil
61 2X4 conversion
Re: 61 2X4 conversion
Not 100% sure of this, but I don't think the low choke models will work with the stock fuel lines. I no longer have a WCFB here to look at, but it seems the offset is different. See if you can find a picture of a high choke model and look at the shape of the fuel inlet. You may have to custom fabricate some lines.- Top
