Battery Cable Grommets for early 69 - NCRS Discussion Boards
  • Dan M.
    • November 1, 2000
    • 48
    I'm ready to install a new set of cables but can this be correct?? The grommets are the same size and configuration but orientated differently which means; I'll have to insert the negative cable with grommet from the inside of the battery box and the postive cable with grommet from the outside of the battery box.
    Thanks in advance for your help and input
    Dan
    NCRS
    35068
    Dan Morlang
  • Bill Clupper
    Re: Battery Cable Grommets for early 69
    Although I'm not real familiar with the '69, What you are describing is very probable, because the neg is installed on the body line (I know ny '72 went in from the top down, and the positive is generally installed on the engine line and the engine then mated to the frame, which pretty much means it would have to pull up into the box.
