1965 Body Lift - NCRS Discussion Boards
1965 Body Lift
  • Ray C.
    • June 30, 2001
    • 1132
    1965 Body Lift
    I hope to lift the body from my 1965 Roadster with-in the next few weeks. Has anyone used the body lift straps? Did they cause any damage? What is the weight of the body? Is there any other helpful hints that I should be aware of?
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Scott Marzahl
    Re: 1965 Body Lift
    I used straps to lift the body on my '67. I had the doors off of the car so I welded up some metal extrusion to take their place, which bolted to the door hinge area and where the latch goes to keep things from flexing. Once I started lifting, the rear end of the body started drooping, I found the "tunnel" area cracked where it meets the storage compartments. This area provides a lot of strenth. I would look for that. Paragon offers a booklet for $5 which outlines repair of this area.
    • Boyan B.
      • August 31, 1999
      • 187
      Re: 1965 Body Lift
      I used 8 people to take the body off my 63, with 6 actually lifting (2 were backups) and had no problems. It was pretty easy and the cost of pizza for lunch was cheaper than the lifting straps....just my 2 cents.
      • Boyan B.
        • August 31, 1999
        • 187
        Re: 1965 Body Lift
        • Ray C.
          • June 30, 2001
          • 1132
          Re: 1965 Body Lift
          Sounds like a plan!
          Thanks Ray
          Ray Carney
          • Ray C.
            • June 30, 2001
            • 1132
            Re: 1965 Body Lift
            Sounds like a plan!
            Thanks Ray
            Ray Carney
