Hello Gang: Well... as usual, I come before you with a question. I began re-assembling my windshield with new rubber installed; for some reason, I chose not to open the good book first (ST-12); I got the top channel and top trim and two side cast pieces assembled first then installed them over the rubber, a little glass cleaner for lube here and there, all set. Now, I try to install the bottom chanel and trim piece as a unit (with the back-up tapped plates in place), I have it close but not quite right, and the tapped plates have slipped. Rather than bang my head on the bench, I trach for the book and low and behold, I've done it wrong (big surprize there!!!). It says to assemble the bottom assembly (complete with trim) first, then the sides, then the chanel alone, then the top trim. Before I take it all appart, any thoughts before I take it all apart again??? My better judgement says start over, but if anyone has tried it by the book and had trouble... I know... start over!
Thanks!!!
Jim
Thanks!!!
Jim
