Thanks to the fine people answering questions on this board, I was able to determine that my temp. gauge is good and the engine temp. sensor is working.
The problem now appears to be the gauge function. Like others, I have found that at 180-185 degrees of engine temp., the gauge is pegged at the right, past 220 degrees. This makes the gauge useless as an indicator of engine temperature, obviously.
I have read that some have included several resistors in this circuit to force the gauge towards a more realistic reading, and also have now read that due to the way the sensor functions, this may be a recipe for disaster as the gauge may not give an adequate indication that meltdown is approaching when the circuit has been modified in this manner.
What can I do? I don't need complete accuracy, but it would be nice to know if a catastrophic event is imminent. Any advice gladly accepted.
thanks
-Matt
thanks
-Matt
