Midyear Convertible, the driver-side firewall wire harness plug has a loose prong (upper row right) which now is receding into the firewall and causing the connection to fail, hence my interior lights, brake lights and tail lights only work intermittently. It appears that this conector is a permanent part of the firewall, can anyone suggest a fix? I am considering stuffing a nail inside the loose prong to wedge it in the extended position as a rig repair, but was hoping perhaps this might be a part I could install from under the dash for a long-term permanent fix. Thanks for any help.
Lights out in LA
Lights out in LA
