Wiring Harness - NCRS Discussion Boards
Wiring Harness
  • Myles Kukurudz
    Wiring Harness
    Good Day Gents,
    I am currently replacing the firewall forward part of the harnes and am trying to determine the correct routing,here are a few questions
    1)Does the harness run on the bottom of the header bar or the back edge ?
    2)I believe there are two plastic clips as part of the harness and 4 green clips for the header bar are there more clips in this area ?
    3)I assume the parking lights have the connector embedded in the inner fender can anyone supply measurements for the hole locations ?
    4)I see the regulator mounts to the left of the alternator can anyone supply measurements ?
    Thanks for your support
    Myles
