u joint grease fittings - NCRS Discussion Boards
  • Glenn28132
    In replacing the u joints on the half shafts do you prefer the grease fittings type or the ones with out the fittings
  • Chuck G.
    • May 31, 1982
    • 2029
    Re: u joint grease fittings
    Originals had no grease fittings. Replacements have grease fittings, and some consider them "weaker" because of the internal passages drilled to spread the grease. You can get original style no grease fitting U joints. For a chassis judge, the fittings stand out like a sore thumb. Chuck
    • Chuck G.
      • May 31, 1982
      • 2029
      • Clem Z.
        • January 1, 2006
        • 9427
        if you put the grease fitting in compression not tension side when you install them there is no strength problem as we have use the ones with grease fitting in drag race corvettes with no problems.
        • Clem Z.
          • January 1, 2006
          • 9427
          • Al C.
            • July 31, 1999
            • 274
            How do you distiguish which side?
            ... Al '58 #378 245hp
            • Al C.
              • July 31, 1999
              • 274
              • Clem Z.
                • January 1, 2006
                • 9427
                al i will send you a scan.
                • Clem Z.
                  • January 1, 2006
                  • 9427
